You need to get new rear springs, Polaris always has soft springs in the rear made for 150 lb person or less, I weigh 220 I always order the strong square springs from Polaris, they are good for a 300 lb person even, this saves your shocks, then you can set your shocks to soft or medium and have a great ride.
Even the new 2011 800 Rush,
I ordered the strong rear springs, switched out from the start.
Also 2 years ago I had problems with the 2009 dragon it had soft springs it sucked, switch out to stronger square springs the sled was great, I thought the walker shocks were bad but it was the weak springs.
Even back on the 700 I wore out the fox shocks, in 2 years, had to buy new shocks and springs, Polaris needs to have an option soft square springs, or stiff square springs.
There's no difference in weight maybe a 1/2 pound for both with the stiffer springs.
If you get the the new springs put it on the med setting, then the next year high setting, this gets all the sag out after the first year of ridding, and then the springs brake in perfect.
This is the fix for your sled I learned 26 years of sleding.
