I have a 2001 Arctic Cat ZL 600 EFI that a Piston ring caught on an exhaust port and broke the Piston. A friend is helping me rebuild the engine. I bought refinished Cylinders and Wiseco Pistons. I’m sending the Lower End in to a friend of his to pull it apart and clean it and make sure nothing is wrong with it. Once it is all back together and running do I need to run oil in the gas?? If so can I use the same Amsoil I run in the sled?? Is there a break-in period?? If so, what speed/rpm max and for how long (miles)?? Thanks in advance for any help
