As a current Polaris owner, you need to make note that when you buy a Polaris....first thing you do is go thru the sled from top to bottom and end to end tightening bolts, and checking for wiring and hose routes with a hand full of plastic lock ties at the ready. Not sure why they can't do this right from the factory but I believe it reflects poorly on a product that has suffered from this issue for years. You don't have to be an engineer to see that hoses that rub, or wires that rest on sharp edges will present problems eventually. While I have owned every maker of sleds over the last 25 years and know that all of them need this attention to play it safely, Polaris is the worst out there. An ounce of prevention is worth a pound of cure. Enough said about Polaris....
