repair motor or replace motor?
02edgehead
i just blew my 2002 edge x 600 and found i took out a piston, cylinder, rod, and probably the crank.11000 miles. how much to repair as compared to finding a different motor?? im leaning towards a new motor. live in oshkosh wi area wondering if anyone has a motor??
jimfsr
See if poo has a short block kit available. You can get Ski Doo OE short blocks, not sure about poo.
shawnl
If the crank is bad and a cylnder and the rest of the mess. You will be better to bolt a diffrent motor in with labor and parts a diffrent motor will be cheaper. With a 11,000 miles your money was well spent
Shawn
gade09
I have a complete 02 motor I removed from my 02 edge with damaged tunnel that I will be selling. Let me know if interested. I am in the Manitowoc area.
gade09
Complete including clutch,carbs,exhaust valves,ypipe,mounts,coil. 8300 miles with 120 compression on both cylinders. Want $500.00 firm.
02edgehead
this is a 600 correct? are they the original exhaust valves? anything else done to motor?? my phone# is 920-716-4118. please call me or leave me your #. consider it sold.
polarfreek
I just did a rechromed cylinder, one piston, all the rings and had the crank rebuilt on an 01 XC800. 4800 miles. That cost about $1,100.00 just for the parts. If you buy another used motor, I would tear it down just to make sure you know what you got. It's worth the $30 in gaskets just to make sure.
polarfreek
Better yet. If you dont have a ton of $ in the chassis with 11K, i would just sell the whole thing as is. I had a friend who just got $1,100 for the same sled with blown motor on e-bay.
dab102999
X2 on that statement. A little investment here will really pay off in the long run. Not to mention even if you have to rebuild that is still a good price for everything you are getting with it. A lot easier to do it on a bench then in the sled anyways.
02edgehead
motor went in great. started on third pull. ran it thursday night around yard and took it out on trails today for 70miles and it sounds good. thank you gade09!!!
