Greatwhitehope
Ok guys I need some help here. I had a new bearing put on my jack shaft and now when I go to put it back in it seems that it's hanging up a 1/8 inch or so. I'v put the bolt back in on the gear and tried to tighten so it would pull the shaft into place but it's just not moving. Is the gear and shaft supposed to sit flush with eachother on the outside? My shaft is set in the gear about a 1/8 inch yet. I'v hammered the clutch side pretty good and it's not moving. So I'm wondering if it's in all the way and they just pressed my bearing on to far? If someone could post a close up pic of a xp with the black overflow plug in the chain case pulled and the bolt removed that would answer all my questions. Thanks
