hey, don't bug out now, we're just getting to the good stuff. Are you saying that a 15 min run in 70 degree temp will not sufficiently warm the engine up to normal operating temp? With a cooling system dependent upon snow to keep it cool, how can running it not allow it to warm up thoroughly. I believe I can run my engine till it blows if it doesn't have a safety. Heat isheat and if the enging is producing heat than that heat will dissipate through all metal surfaces given enough time.
So bottom line to you is that it will not come up to temp unless underload, just asking?
Yes, that is exactly what I am saying. It is not that the coolant temp will not come up to normal, it is that the exhaust/combustion temp will not come up to normal without a load. If you really need to prove it to yourself Lenny, the answer is simple. Install a set of egt's on your sled. Run it on the stand with no load, up to normal operating temp as viewed on your coolant temp gauge. Note what the exhaust temp reads at that coolant temp. Next, take the sled out and run it under load. Bring the coolant temp up to the same value as you did on the stand. Note the exhaust temp with the engine under load. Get back to us with the results and let us know the difference between the two readings.
