RISER???
skidoocadets8
Im looking to buy a riser to buy for my 01 mxz 600 adrenaline... looking for highest riser i can get w/o getting throttle extensions
suggestions, prices, places to get them at???
thanks
jimfsr
I think 2" is all you can do. remove the bar clamps and see how far you can pull the bars up and have clearance. You will run out of brake hose before throttle. You might be able to swing 3".
There are several riser blocks avalable. All pretty much the same thing for the non-pivot style. SPI and powermadd make all sizes in a straight riser. RSI makes an angled one to tip the bars foreward 30 degrees. ROX has several that you can pivot the bars to wherever you like.
Prices go from about $20-150, depending on what you want. Any dealer should be able to order these for you, or do a web search.
