Risers/longer cables?
just re-route the cables. No need to spend $30 on a riser, just buy longer bolts and stack LOTS of washers on top of each other.
hemi_newman
Dont listen to this^.More than likely you will need longer cables. I only needed a longer throttle cable as i was able to reroute the brake line.
I had a 5" riser and didn't need to extend anything. my handlebars had 2-3" of rise in them over the almost flat stock bars and i had a 3" block riser. I took the handlebars off cuz i didn't like how they looked after a while
jeff
have an 02 edge X put 3" riser in it added longer brake cable but didnt need to ad extended throttle cable might have gotten by without brake cable but kinda tight better safe than sorry. hope this helps!
