groomerdriver
the roof truss design criteria will disrtibute the loads to the proper places, usually the outside walls or beam trusses and then down through those walls to the foundation.
my concern beyond slipping to injury would be that in most areas new construction allows 1/2" or even 7/16 OSB is roof rated to 24OC as roof sheathing, now add your body weight to an already heavy snow load between the trusses and whallah....you could end up in the living room with your boots on!
Now old consruction poses even greater danger due to age and lax or no codes or rated lumber back in the day and then add 2 or sometimes 3 layers a roofing material and you are cruising for problems.
I've stripped old roofs with 6" knots falling out of the random width roof sheathing boards and those are on sitting on 2x4 rafters!!!.
Our house is 5 years old. 2X6 construction. L-shaped house (garage facing front) with Vee roofs. Built by one of the best builders in the area. Should I be concerned about the amount of snow up there?
Was going to ask: what is the best composition for a shovel to use on a shingle roof?
