Donzi Classic
I"m buying a 2007 Summit 800R Power Tek. Everything is stock except the clutching will need to be changed for non mountain use. The sled has been used only out west. The seller states I will not need to change the jets in the carbs. I thought only SDI motors worked like that. I will use the sled in the U.P. only. I'm looking for some input
Thanks.
Thanks.
