Ok I have an interesting one. 700 tripple in a CK chassis. The sled will run for a short while (2-3 minutes) and then just die out with no spark. After a minute it will start back and do it all over again. I know these sleds have had some wiring harness issues so I pulled the harness and direct connected the CDI and DESS switch into the stator and coils. Again, I know these sleds had stator issues and it is jut about impossible to test while running. I have swapped out CDI boxes with the same results. The stator tests OK and the pick up tests OK 99% of the time. My hunch is the stator even though I have only found open circuit a couple times when testing. It is like heat and vibration open a circuit to kill my stator, but will cool down and reconnect very quickly. When it comes to the electrical gremlins on sleds I am on the edge of my comfort zone. I would rather it just fail completely but I guess I can not be that lucky. Has anyone else ran into CK tripples with similar issues?
Thanks in advance
Thanks in advance
