I have a 2000 Mach Z 800 and when a bulb blows or something goes wrong there is the red "warning " light on the dash that comes on. I beleive the light is also for low oil level also. Recently I had a voltage regulator take a **** which caused both headlight bulbs to blow and the taillight to blow. I replaced the bulbs and we pu in a new volt regulator today and noticed that when you put the brake on the red warning light comes on. Everything as far as bulbs seems to be good again and I know there is enough oil in it. Any ideas as to what is the cause of this??? Thanks for the help! Dan
