Don't feel too bad, I pulled that 1 before. Between the shop I use & me taking the clutches on & off several times we streched the bolt and it snapped on me. I wouldn't heat the splines , most important is your procedure. Smooth out the broke bolt end if you can, use a center punch and try to center punch it on " center ". Use a " center drill or pilot drill 1st then open up to your E-Z out drill size. The stud might spin to the bottom of the hole, that's OK at least you know it will come out. Use a good drill, for bolt removal I like cobalt drills ( for everything actually ). You will generate enough heat from the drilling process . It is important to drill on center so you don't cross over into the minor & major thread diameters then stuff the E-Z out in there and rip things up in the process. To start you might want to try an air gun and a scriber or small ***** punch to see if it moves or you can back it out. OR feel free to use a left handed drill bit if you have 1. 1 more thought from experience, worst thing you can do is get your hands on a carbide drill bit and then unfortunately have that break in the stud, or snap off a " cheap " E-Z out off in the hole. The worst senario would be the carbide drill and the 2nd worst is the hardened cheap e-x out. If you run into problems post back and I can give some more input, below is a picture of the " center drill " , it actually called a drill & countersink .
