Had a friend turn thottle around, work fine until he had to make a quick turn to right, opened thorttle wide open lifted the skis and ran off left side of trail into trees!
Kinda like people getting bucked forward and into the throttle in it's current position and pinning it, it happens. Another concern with a forward facing throttle would be tree riding and having something strike the throttle but handguards could help with this issue. Sounds like the OP is doing more on traill then off though so that may not be an issue.
Not to mention the kill switch and other control switches being upside down & backwards, in theory a decent idea, in reality, not a good idea.-Mezz
Yes, maybe I should have been clearer (or worded things differently in my post). You would need an aftermarket throttle block and either an aftermarket tether or kill. You couldn't simply "spin the throttle block around" as I said in my post.
The OP has an 01 Edge X, I had an 02 Edge and put an aftermarket throttle block and tether on my sled. Certainly not a complicated process or an expensive process.
If you want to stop having a sore throttle thumb than stop using your thumb for the throttle.
