alright i have been trying to get my 96 xlt sp 600 going. i have ripped all 3 carbs off cleaned and put back on. cleaned fuel pump, changed fuel lines, and emptied gas tank and put fresh in. i synced all the carbs so pull at the same time. now this is where it gets fun. depends on who you talk to or read on here rough set-up varies. as of right now needle valve is set in the middle position. air screw is 1 turn out. and idle screw is set 4 turns in. i have messed with air and idle in 1/4 turns either way and still no results. getting frustrated quickly. any help is greatly appreciated.
