You can also soften the front shocks, which when coming into the corners, will cause more weight transfer to the front, and more ski pressure. Also, make sure the transfer blocks in the skid are set to let the sled move forward. The blocks are on either side of the scissors mechanism. You'd want the shortest setting for the front block to let the sled lurch forward a little more when slowing down.
