Studs For a F8
para_rider
Just wanted to see what you guys think on how many studs I should put in. Just trail riding. It doesnt need to hook up hard. I just want it many for icey hills and stopping. One more thing ANyone out there use the deuce Bar for stud boy? I need the best turnin carbies out there. Im parazied from the waist down and cant lean like I use too.
mjkaliszak
Best carbides out there ?
Bergstrom Skegs Triple points.
Studs, my rec would be 96 down the middle.for your application. You will need to match carbide lenght with how many studs .
catalac
Yes I think you could get away with 96 or even 144. The triple points are the way to go also. They are expensive, but you definately get what you pay for. They last double, or even triple the time of regular carbides. It's good to hear that your still out getting your snowmobile fix. Good luck to you.
sr22ger
It's 102 and 153 respectively for a 128". I ran 102 in my 07 F8 and it seemed to be a good balance. Not sure what I'll do with my 2010 though since they changed the chassis a bit.
