1flatlander2
the moisture in the past was from condensation. now with the ethanol in the fuel the only way to keep moisture out would be to seal your tank from the atmosphere. adding stabil and seafoam to fix the problem of moisture in the gas seems redundant to me. when you drain it there is no problem to fix.Thats funny that all these years I've been filling all my tanks to keep the moisture out and adding stabile turning the fuel off and running them till the carbs are dry. Then in the fall/new years when I get them out I add Sea Foam and fire them up never had a problem. Draining all the gas seems like a pain. Then grease and all that jazz too.
