Swamp riding today
ubee
Swamps and lakes not to bad today after LES dusting. shops doing a good hyfax bizz in some areas! best to call ahead to your ride spot and check on conditions
longhair
Swamps
So I'm not the only one that like to play in the swamps it can be some of the best riding
Swamps are awesome! There's a swamp at the far southwest end of lake noquebay in marinette county I like to go play in, closest to off-trailing i've ever done! Except for I got stuck and was lucky to get myself out since that lake is HUGE and No one would've found me :/
roc
ubee in the MUD-Marsh
7 guys to get this one out
Ubee where's a polish snorkel to keep the water from getting up his nose lol
ubee
Rocs power steering belt blew !!
upsledder
Sure you don't mean the northeast end? southwest would be around Timberline.
Talk about never being found. Back in 1985 I was riding alone, air temp was about -20. I got to close to the inlet near Maple Beach, dropped it into 14'. 8 hours later you would never have known a snowmobile went through that spot.
mjkaliszak
Too funny... is that what happens when you wear a Yamaha helmet ?
Love the hotdogs, that must be after the muck hole ?
ubee
Got frost bite in Alaska and have to cover up when -20 and 70+ mph or more. Yami sno-force is a great helmet and never fogs on me if I use breath deflector and barely crack open the shield ! Yami good on ice if you follow camoplast break in proceedure and keep it adjusted to their specs! 2nd set of hyfax in 6200 miles. Use good OEM hyfax,break them in hot ,pack with snow.They will wear down to 10mm in wear spot in short time ,but will stay there for long time if no roads ,snirt,glare ice etc. I use 10mm open end wrench for a wear guage in thinnest spot ,easy check ! I used to run tracks loose till they rachet in deep snow but that caused alot of damage ! 1 inch in center of rail with 10 kg on spring scale ! I know I will get alot of feedback on this one but it works !
ubee
swamps got a little soft today !
OK, now I'm homesick. There's just nothing like the sweet sound of frozen Tamarack hittin' the pan.
