yep Indy you are absolutely correct. I have done a couple of these.Shouldn't need to pull the motor. Drill out the rivets pull sway bar and install and re-rivet. I would recommend replacing the bushings.
Indy you never stop impressing me. Also add to replace the plastic part that goes into the trailing arm. Sometimes it takes a bit of wiggling to work the sway bar out if it is bent.Shouldn't need to pull the motor. Drill out the rivets pull sway bar and install and re-rivet. I would recommend replacing the bushings.
wiggle like crazy, it will come out. kinda like one of those "bent wire games". Don't pull the motor, then you will have the hassle of aligning the clutches back up. I put a floor jack under the center of sled and let the skis hang a bit to get out. NOW????? why do we call it a sway bar?????? when it creates "anti sway".did you guys get the sway bar replaced? I have to do it on my sled as well just wondering if there are any tips that i might need?
