Well, here's the deal. I purchased this sled this fall. It's an 07 polaris switchback 600 cfi. It came with a slp pipe and silencer on it. I installed the slp big horn air intake, and had the dealer replace the fuel filter, check the oiler cable and pump setting and install V Force 3 reeds plus a slp clutch kit and regear from a 22T to a 21T. I have NGK plugs in at .28 gap. I'm running polaris VES gold oil. As mentioned I just purchased it in fall...1/2 a tank of gas from previous owner. I filled the rest w/ 100% 87 octane. Played a bit and refilled the tank (about 4 gal. worth) of premium gas.
Here's the problem......
It backfires thru the exhaust intermittently on de-acceleration. When I'm coming off the field and going into a turn it backfires right before I get into the turn. I've put 240 miles on and its backfired maybe 5 or 6 times.
The other part of the problem is this....
It has the perc reverse and I had to back up a few times and when I hit the button, as the engine drops in rpm it gets to the low point, backfires then kills the motor. This happened about 4 times in a 10 minute period. Again, this problem is intermittently as well. I use reverse to back into my garage everyday and has never happened before.
I called slp and they are suspecting low grade gas at this point. I'm in the process of adding a bit iso-heat (the red bottle) and lucas octane boost(recommended by slp) and thru my calculations I'm at a 58 : 1 ratio in oil consumption which I thought to be on the lean side and slp agreed and said to put it about 40 : 1. Thur is my appointment to up the oil ratio at the dealer. Other than the backfiring issue, the sled runs GREAT, pulls hard, and has all the power that you would expect from that motor w/ its added goodies.
Am I on the right path??????
Any ideas????????
Any ideas????????
