On all the Polaris sleds I've owned I just remove the bolts, pry the slides back with a screwdriver 1-2 inches, then reach in and clamp on with "long-nose" vicegrips and pull the slides out the back through the track window. On my newer Yamaha's, no joy, have resorted to either removing the suspension, or have done the reverse trick a couple of times. Painful to use big screwdrivers to pry the hyfax from the rear of the slides each time - chewed up aluminum. I never thought something so similar could be so different on two different manufacturer's sleds.
I finally invested in a sled lift last year and that makes the job go MUCH better. Still a PITA on the Yamaha's.
