Typical mix ratio on a new or rebuilt motor is 40:1 gas oil in the tankd PLUS your oil injection oil. Your doing a couple things. A) just in cast your oil lines have a little air bubble in them you are making sure you are still geting lubrication to the engine. B) your making the the whole enigine run "wetter" so the little tiny wear metals that are generated upon break in are flushed out of the engine via the exhaust.
Also, remember to baby it for the first tank of gas. The first 1/4 tank, warm up the engine really well, go easy, no full throttle at all and vary your speed. 3/4 tank up to 1/2 tank- increase your speed a little, short bursts of speed not to exceed 3/4 throttle. 1/2 to 1/4 tank- short burst of full throttle, increase your speed while varying your speed. The last 1/4 tank- longer bursts of wide open throttle, vary your speed, and that should about do it, she should be broke in. Pesonally i'd still take it a little easy for some or most of the second tank but thats just me. I mean hey, rebuilds aren't exactly cheap.
