You were running wide open.
What was your gas level ? Low tank and sloshing gas, you could have momentarily sucked air ?
When was the last time the fuel filter was changed ? First sign of a restricted fuel flow would happen during a full throttle event.
Going into limp mode is usually caused by an overheat. You should have seen the dash light as you did on previous overheats. It's starting to sound like a fuel delivery problem. ??
I was at about a 1/2 tank at that point I rode another 14 miles then turned around at the turn off for Lake of the Clouds and went back to Burgland. When I got back my Low fuel light came on and the gage cluster saying "Low Fuel" as I pulled into the gas station. I put in 8.3 Gals. I have a10.4 Gal tank.
But it is interesting you mention this, my friend that was with me, had bought a 2014 Viper from another one of are friends two seasons prior. Due to a move and his wife having some health issues This was his first real trip north. He was also starting to have interment hard starts around Christmas. Like the sled was not receiving fuel. He decide to drain all of his gas knowing it had sat for at least his two years of owning it. In doing so, the filters just disintegrated. He also then realized that when turning on the key the fuel pump was not primping or pressuring the fuel tank. So he end up changing his fuel pump and filters. With mine being a 2015 and very similar to the same parts... I may have to check out my fuel pump. Just to make sure its not the same issue starting. I do know everytime you turn my key you can hear the fuel pump start up so far.
As for the Filter I thought it was changed two years ago but I don't see it in my notes. So unless I forget to write it down, it may need to be done. I'm fairly detailed on the notes I keep, a habit my Grandfather got me in when I had my first car. He use to keep a small note book with miles, dates, and everything done, Including every fill up. I now use a app called "fuelio". If you like know all this info it real is a good app. Being an app I can literality look at graphs/ trends, see fuel milage, Cost of maintenance, repairs, parts, overall cost for each vehicle, etc... All depends how detailed you are when toy put the info in the app. I keep track of every vehicle I have on here. I even use it to track mileage and cost on my trailer. I'm sure this seems crazy, but it is nice knowing how long brakes and tires are lasting on the trailer. Plus if I want the data out it can be exported to Excel easily.
