Follow the wire down the bar to where the connector is. Then take it part, get out the trusty multi-meter and check the resistance in the thumb side. If it is an open circuit you have a broken wire or a failed element. IF that is not the case, switch to volts AC and test the sled side while the sled is running. should be between 8 and 12 at idle.
