snowfish
Only the spindle needs to be sanded. Not the bearing itself. This is an extremely close tolerance fit. Thus the Very Clean & Oil recommendation. Any oil will do. Even the WD-40's and JB-80's, of the world, will work fine. I use oil or spray lube because it's easier to clean off When you have to sand again.
I see some rusty, crusties, and knicks behind the bear on the last image, that needs to go. The seal surface look pretty rugged too.
Yep, lots of elbow grease!
Really doesn't matter how you clean up the castle nut threads, as long as you can move it by hand.
I picked up a full tap & die set for $75.00 from tools & more, which included the 1 inch tap & die.
No worries, Mate! You about have 'er wooped!
