What kind of trailer?
Marine plywood, like on a pontoon deck. But, it is pricey.
It is a alum. floe snowmobile trailer. not covered, and will be stored exposed to the full sun and elements
Been doing a little research and seems that pressure treated plywood may not be the best option. The new chemicals they use in P/T plywood will corrode the alum. would the alum. not corrode if I coat all the cross members with rhino liner? also what about alum. rivets? I want a good deck but don't really want to spend 300 to get it.
If you put track mats and ski glides on it you would be fine since no part of your sled will be in contact with the wood decking. Pressure treated plywood with a annual coat of sealer with mats and glides will last you longer than you'll keep the trailer.
not worried about my sled my concern was the trailer. I am not putting ski guides and mats on trailer as I use it for many other things and don't want those on there. .
Mezz-- 3/4" won't fit under the lip that is used to retain the outside edge of the wood.
