If there is a dealer in your area for the manufacture of the trailer I would start there.You can look at trailers that are finished and can order your cabinets and materials there.Insulation really not needed unless your heating it.If your budget allows we always have colored bedliner sprayed on the floor and it really holds up well.You really have to spin your track to even stratch it with picks and the carbides don't either.I have an in-line trailer with a bare interior, looking for suggestions on finishing it, what kind of wall panels to use, where to buy cabinets, should i insulate, any ideas would be appreciated,Thanks.
Howdy ff, I had a company that leased space from us install the bed liner (Carefree Coatings in New Lenox IL. Actually the carbides slide better on the coating than plywood.We installed the plastic ski runners on the floor and the sleds really slide now.I will take a picture if I get time today of the interior.Alot of trailers have plywood up the sides about 18 inches to take the hits and we had that coated also.Also the bed liner makes a excellant under coating for steel framed trailers.I am going to do a finishing project on an aluminum R&R trailer. I have been researching the subject, and had come across another site that I can not find now where they finished a cargo trailer. They used FRP (fiberglass reinforced plastic panel). I have been searching, and found Lowes has the best price I could find at $288 / 10, 0.09 thk 4' x 8' panel white pebble textured. Common application for this product is high wear surface, bathroom, car wash, and ceiling. I have also found a 3M product to adhere fiberglass to aluminum (3M 8116). I am thinking I would place a bearer Styrofoam ridged insulation behind the FRP.
Now I like the idea stated here about using bed liner on the floor. How do the carbides slide on this? Almost seems it would be sticky to slid on? Is Rhino liner the product used?
pit pal or pit products. They will have anything you might want. Google them.
