skidoodoug
Do trailers in Wisconsin have titles (like Illinois) or just registrations? Illinois has both.
A title and registration is not required for trailers operated at or less than 3,000 pounds gross weight unless used for hire or rental, over 3000, YES. Title and registration is encouraged for these vehicles that will be used on roads outside the state of Wisconsin, as other states' registration laws may be different.
If you want to register a trailer you need the original (no copy) MSO or a title. My brother just went through this. He bought my trailer in Michigan and then sold it later. For the new owner to get a title (he wanted that) they needed one from Michigan. Michigan did not issue me one for under 2,500 GVW. But I could get one (for a fee of course) ONLY because I was the owner of record. My brother could not get one from Michigan and Wis would not honor the Bill of Sale for that purpose. Copies are worthless, must be an original document issued by a state. Luckily in Michigan you can now get a title instantly at any DMV office, for an additional fee.
MSO - Manufacturers Statement of Origin. Dealers are required to surrender to DMV to title or register a vehicle.
Hopfully they will not require an inspector from the dot to inspect it too. I've seen that happen.I'm going through this with a skid steer trailer. Thought a BOS was ok to use.
Now they want a title bond for 5 years an pics of the trailer from 4 sides.
Jezus....I basically rebuilt the entire trailer.
Illinois has both.[/QUOTE said:That's because Gov Pritzger has his hand in our pockets for EVERYTHING! Can't cut spending, just tax more!
FWIW - I have two trailers that can carry over 3000#'s in WI and neither have a license, but both have titles. Never had an issue, and I don't know anyone who has.
From WIDOT, "If the gross vehicle weight (GVW) of the trailer is under 3,000-pounds, then licensing the trailer is optional." Based on this, my unlicensed Triton open 4 place (1100lbs)is legal loaded with 3 sleds, illegal with 4.
Pretty sure GVW refers to the fully loaded weight capacity.
If the GVWR from the manufacturer is under 3k you dont need registration. Even if the trailer has 3500lbs axle its all about the GVWR. Manufacturers all use 3500 axles for the lightest axle. So just because your trailer is actually capable of hauling more than 3K GCW, its what the manufacturer rates it at. Most trailers with 3500lbs axle are rated at 2990lbs just for this reason.
I have been given a warning for an unregistered trailer with a GVWR over 3k. State trooper are more likely to notice than city cops.
I know in wisconsin you must have a spare,or you can be ticketed. You may also need mirror extentions for your vehicle for enclosed trailers. Illinois, you need a plate but no spare. Which law makes more sense. Good old IL!
