So I took somebodies advice from here and decided to do some long overdue trailer maintenance. I usually pack bearings every other year but had missed the last few years. So I got after it last week. Had a lot of trouble getting stuck lug nuts off, finally just took each wheel and hub completely off. Then used a breaker bar and pipe to get all the lugs off. Spun one stud so I ground that off to remove the tire. Once I had it all apart I decided to blast the hubs and wheels and repaint them. With that all done, bearings all repacked, new seals in place, new stud installed in the one hub, I put her all back together.
This weekend we head to the cabin and brought the trailer with so we could aul back some wood. After I load it I check the tires again, all the lugs are nice and tight. About a mile from home, its about 80 miles to the cabin, I look in the mirror and think it's strange I can't see the front tire on the drivers side. Get the rest of the way home and look and it is gone. Broke the lug studs off. Don't know for sure what caused it but am thinking the force I put on it to remove the lugs maybe weakened them. The nice thing to know is that the trailer pulls fine missing a wheel. Now though I debate replacing all the studs on it.
