So i took the carbs of my 600 triple polaris (round slides) to replace the carb boots and clean them up. Noticed that the center carb throttle and idle air screws were farther out than the other 2 carbs. Think I should set or sync them all properly since they are easy to get to now. Never done this before, should I set throttle stops or idle air first? I have one of those vacuum gauges that you hold over the carb inlet but not sure exactly how to use it. Any advice would be appreciated< thanks.
