garyl62
I know there are usually 20 and 30 amp hook-up at most campsites, more and more have 50 amps as well, but I to make sure my home-made trailer hook-up will be correct when I hit that first campground.
I'm only planning on a 20 amp service and I'm wondering if the outlet to plug into is a typical straight blade with ground (2 verticals) or are they usually dedicated 20 amp outlets with one of the straight blades vertical and one horizontal?
If they are the latter option, what do you use for a extension cord to the trailer? Easy enough to make my own, but can't seem to find one to buy with the horizontal blade set-up.
Thanks
Thanks
