Water Bowl's
machz05
Looking for some aftermarket water "bowls" traps for the carbs on a '03 Ski Doo Rev 600 HO. We are rebuilding the motor and want to change a few things on the carbs while we are doning this. Does anyone have any idea where I can order these aftermarket parts?
jimfsr
I have seen the aftermarket drain plugs for some carbs that have a hose to trap water, but you have to empty them occasionally if you think you have water issues. Not sure if they are available for the flat slide carbs or not. Mostly a polaris thing, as far as factory usage. You could drill ald tap a 1/8" NPT in your existing carbs drain plug and make your own hose drain, if you think you really need it.
I don't recommend doing that. I have drain plugs on mine and the hoses running off the bottom of the carbs go straight into the bulkhead and rub on it, my hoses looked terrible, and there was almost a hole in it, glad i caught it. Although, it is nice to drain em before completely tearing em apart.
