I decided to pull the suspension out of my old RMK and go thru it today and came across a couple issues. Going to replace idler bearings and slides after 6800 miles but the bigger issue is on one of my rails there is a crack from the top down to the bolt hole for an idler wheel, about 3/8" long, and on both rails where the front shock mounts the holes on both rails are egged out badly. Would I have any luck if I welded up the crack and then filled the holes with weld and redrilled?
Also, next question, going to replace the bearings on the drive shaft. How do I get the bearing off the shaft? just use a puller?
Thanks.
Thanks.
