garyl62
My company just bought a couple buildings that had been used as rental units for the past several years. We will use them as a group home set-up to help people be self sufficient after completing some treatment programs. When I did the walk through in one unit I saw this black film on the walls and ceiling, but it only showed up on the wall where there were studs or trusses. The unit was basically clean except for these areas, but you could tell the people that lived there had a lot of grease or grim as part of their life. There was grease/oil spills on the deck leading to the front door, looked like they had thrown something that had splattered against the siding at one time, and the utility sink was very stained with black grim that looked like it had been part of the soapy water discharge of a washer and left residue on the sink. The other thing I noticed was that there was a 90+ furnace in the unit, but the PVC pipe for both the fresh air intake and discharge air had been removed so everything was being pulled from, and dumped into the basement right by the sink.
I didn't have a ladder so I couldn't touch them so I can't comment of that, but this was on the main floor of the unit and in the basement there was a little mold on the drywall in one room. None of the other units had anything like this.
Any ideas what it may be, what caused it, or why it only stuck to the wall where there was framing material behind the sheetrock?
