Congratulations!!!!Officially retired as of 10-31-2022...
ordered snow-tracker aggressives yesterday, supposed to arrive on the 14th, now I just have to get at my trailer. Any suggestions of set up or just follow their instructions, not sure if maybe you tweaked set up at all. However, you ride Doo, I'm a Cat guy so I'm sure chassis handle differently but sometimes talking to someone who has used them there may be a better set-up. Whitedust too has stressed to me to follow set up instructions, going to let me use his sled lift.you are either going to love them or hate them. I love them. I'm sure Pete has told you to set up the sled correctly. It's important.
I follow the instructions except for changing limiter strap. I bring my sleds to a guy who specializes in suspension setup and let him set the strap where he needs to in order to get the desired settings. So strap is set for suspension purposes and not necessarily for snow trackers. Main thing is make sure skis are parallel. That I always doordered snow-tracker aggressives yesterday, supposed to arrive on the 14th, now I just have to get at my trailer. Any suggestions of set up or just follow their instructions, not sure if maybe you tweaked set up at all. However, you ride Doo, I'm a Cat guy so I'm sure chassis handle differently but sometimes talking to someone who has used them there may be a better set-up. Whitedust too has stressed to me to follow set up instructions, going to let me use his sled lift.
Brian we can mess with it on the trail but I would concentrate on center shock settings prolly harden up get pressure off skis try for full travel with limiter strap then soften center shock until you have eliminated all push. Darren talking about zero toe in when he refers to parallel skis. Darting should be eliminated at any setting unless way too much pressure on skis. Darren has a guy that tweaks shock and suspensions but unfortunately in CanadaI follow the instructions except for changing limiter strap. I bring my sleds to a guy who specializes in suspension setup and let him set the strap where he needs to in order to get the desired settings. So strap is set for suspension purposes and not necessarily for snow trackers. Main thing is make sure skis are parallel. That I always do
Yes.Brian we can mess with it on the trail but I would concentrate on center shock settings prolly harden up get pressure off skis try for full travel with limiter strap then soften center shock until you have eliminated all push. Darren talking about zero toe in when he refers to parallel skis. Darting should be eliminated at any setting unless way too much pressure on skis. Darren has a guy that tweaks shock and suspensions but unfortunately in Canada
