gigakessler
Time for some new tires on the TK trailer. Its a 4-place dual axle that we occasionally use to haul four 146"-154" 2-stroke mountain sleds. The front axle seems like it carries most of the weight on this trailer. We currently have range "C" tires. Thinking about get two higher range tires for the front axle and move the "C" to the rear axle.
Any disadvantage with going to a higher load range? Should we get "D" or "E"?
- Range "C" = Bias tire has a ply rating of 6 and a 1,100-lb maximum load at 50 psi.
- Range "D" =Bias tire has a ply rating of 8 and a 1,320-lb maximum load at 70 psi.
http://www.etrailer.com/Tires-and-Wheels/Kenda/AM3H430.html
- Range "E" = Bias tire has a ply rating of 10 and a 1,650-lb maximum load at 90 psi.
http://www.etrailer.com/Tires-and-Wheels/Kenda/AM3H490.html
