Windshield
tex
I have a big windshield and it is crack on one side. Does anyone know what will fix this crack? New windshield is not an option.
dab102999
Even fixed it will probably flex more then before and crack again; but at the end of the crack drill a hole (1/4" dia or so) [this will keep the crack from getting any longer] and then for the length of the crack drill holes on both sides of the crack. (Big enough to get a zip tie thru) about every 3/4-1" and use zip ties to hold together. It will work, probably for a long time if you don't run really high speeds. I have done it before on older sleds that for some reason liked to be track side up more then down.
Post what type sled it is, you might be surprised and someone here might have one to give to ya....
dab you're right, i got my black and checkered flag 12 in. used windshield for my 99 indy 500 (evolved) for $15. i've seen basic clear used ones at swap meets for $5
oh and by the way, i have a stock evolved chassis windshield and a stock gen II chassis windshield for polaris.
tex
It is a 2006 Polaris FST. The windshieldv has mirrors on both sides, the crack is on the right side where the mirror is at.
Thanks for the input.
dvision
Duct tape it
I was on the 1st day of a trip last year and my windsheild developed a crack after hitting a branch. We taped it up and it has held up. Surprised me. It still has the tape on there after 700 miles. It looks classy too!
blazin4kix
Best fix Ive ever found was hot glue. Usually tape one side hot glue the other then after it is set take tape off and hot glue other side. I have done this many times Ive even done winshields that were broke in half. This works suprisingly well.
zimmbob
I'm with dab. holes and zip ties. get some sexy neon ones. maybe pink so you have something for the guys to give you guff about..... makes it look meaner too... just like stitches.
