I have the unit from Central Boiler and love it. Here are the tips I would recommend:
1) Keep the boiler as close to what you are heating as possible. I realize that this can mean some smoke near the living quarters, but if you put it on the downwind side of the living quarters (for main heating season), then the smoke will mainly blow away from the quarters. I say to put it close to what you want to heat because you do lose a noticeable amount of heat with the pex runs from the boiler to the structures you want to heat.
2) Get the good pex/insulation for the runs from the boiler to the structures. I opted for the lower end, which consists of basically the 1" pex with large pipe insulation and then a plastic sleeve to keep all of that dry. It works, but I don't think it insulates as well as the other stuff, which is basically pex inside more plastic tubing and the pex is sealed inside the tubing with insulation. I have heard this insulates better.
3) Don't burn trash in the boiler, only wood. I have friends that have burned other things and it ended up causing corrosion and leaks.
4) Make sure your heating system is engineered so that you can switch to a more conventional system later on down the road. I know I do not plan on heating with wood when I am old and not able to make wood and load the boiler.
5) If you don't get a unit from Central Boiler, get one with comparable performance. Again, I have friends that opted to pay less for lower end units from other manufacturers and they go through a lot more wood than I. This causes you to spend more time (and sometime money) for more wood, defeating the purpose of using an outdoor wood boiler in the first place. I guess the bottom line is, you get what you pay for in these things- no matter what the claim is. Pay the extra up front and then let the better performance pay for itself. I know I paid about 3K more for my unit, but it has already paid for that difference in wood usage in the 6 years I have been using it.
