I have a 09 cat crossfire 800r. I have installed a 136'' skid frame. i have a 1.5'' track and a 2'' i use in michigan. I also have a stage two speedwerx clutch kit for each set up. It still doesn't have that god of a mid range punch when i'm putting in and out of the trees. I'm thinking its the gearing 64/56 is stock. I'd like to re gear it with a cross between m gears and x-fire gears. I would like to have a good set so it works with both track set ups. any info would be great. Is the diamond drive easy to do a install myself? I have access to a press for the gears if need be.
