1-snowbullet
Hello out there was running my 07 apex last season and it started tinging in the tunnel area at a idel sounded like a beer can with ball bearings being shook . Also buddies 08 Vector same thing .. We both have around 5 thow miles on sleds .. I got currious and took the seat off gas tank and inspection pannels off of tunnel and found that the flex pipes have EXAUST Doughnuts that burn out .. Easy fix Kinda takes 1 to 1 1/2 hrs to get to There are 2 bolts going into tunnel that have button head allan heads on them You might want to figure out how to remove and replace with Stainless hex head bolts these bolts hold y pipe tight in place MUST LOOSEN To pull exaust Backwards to get donuts out THEY GET RUSTY and hard to remove .. same with the vector .. there are flex pipes off of y pipe and block of engine 10 mm bolts hold them to head remove then you should be able to get at doughnuts . your local yamaha dealer has new upgrade doughnut kits availible they come with doughnuts and bolts for clamps .. another 1 to 1 1/2 hrs back togeather and quiet as a mouse no rattles . will post some picks later in the week to display what you possibly would be getting into .. remember all 4 strokes are not the same but if you get a tinging--beer can ball bearing shake sound in the rear of your sled its most likly the exaust doughnuts . i hope this is helpfull to all .. honestly its a easy fix if ignored could be big bucks those flex pipes are not cheep ..
