So I bought a new ZR6000 this fall with the plans to buy a 2 up seat kit to use periodically, not all the time. I ended up getting the 2 up seat, and wiring harness for the heated grips, all from Arctic Cat. Everything is plug and play, no shade tree engineering involved. After everything is installed I can't use the heated grips on HIGH, when I turn them on HIGH the dash panel goes off, the headlight dims dramatically and the taillight turns off. I called my dealer about it, he called Arctic Cat to find out what was up. In the end I was told that the 600 cc engine just doesn't put out enough juice to supply everything so don't use the heated grips on HIGH. Hhhmmm, not gonna lie, it's a little frustrating. Nowhere in the catalog (or online) was there any kind of disclosure stating that the $99.95 wiring harness not function properly on any model.
Has anyone else ran into this problem? Thanks, Ramsey
