Last year the Estart would not work sometimes. Checked battery, cables, Switch all OK. Kind of forgot about it after I parked it for summer,
Recently trouble shot some more found that when it does not work there is no voltage to the solenoid coil. If I jump across the solenoind the starter spins over fine. If I put voltage to the coil it pulls in at spins over the starter. Once running the Start/RER switch will put it into reverse.
My quess is the Start/RER switch provides an input to the MPEM and the MPEM is what actually sends voltage to the starter solenoid. Does anyone know how the Estart circuit actually works on this sled? The Start/RER switch only has 1 pair of wires on it so it must provide an input to a module. Also not sure if the DESS could be part of the problem or not.
Everything else on the sled works fine. This is just irritiates me!!
Thanks
Jamie
Thanks
Jamie
