Whats are some must have upgrdes to these sleds? Im coming off a long tracked poo 600RR so if something got in my way I would just mow it down haha. I know the XPs are not built that tough so, whats out there for chassis bracing? I will probably do a clutch kit right away also. Have you guys riding these sleds at sea level been mesing with the gearing at all? thanks
Must have's (sp?) on my 09 summit XP =
1. Belly pan/skid plate
2. Quick disconnects for the sway bar
3. Scratchers
4. Aftermarket belt deflection adjuster - (Worth every cent!)
5. Aftermarket Can (Not for the noise, but accesibility to everything through the right panel)
6. Tunnel reinforcement kit. (Two buds with the same sled that don't have them are bent)
Other components that are nice but not absolutely necessary......
1. Quick Clickers - Simple and effective way to tune RPM's+ or - 300 r's
2. Tower Brace Kit
3. Shockwave adjustable Helix - (In addition to the clickers, this allows you to tune in the secondary on the fly as well for high and low alt. riding)
4. Tunnel rack kit to hold tanks/packs, etc
5. Switch stock skis inside out. (If you want an explanation PM me)
6. Aftermarket set of bars - (It's only my opinion, but the strength of the stock bars suck!! If you ever need to roll the sled in conditions that aren't bottomless, my experience has been that they bend always bend!! 3 times in a 12 month period)
Good luck. It's a great sled. I've been happy with it, and will be sticking with it until Doo comes out with something drastically different.
