4" riser at minimum. you can use same brake and throttle cables, you may have to reroute brake cable behind the oil tank, that can be done without disconnecting the brake line.Going to put a Rox Pivot Riser on my 04 Polaris Edge. I am 5'-8" tall. Want to be able to ride trails sitting comfortably but also want to be able to stand at times. I know it is really up to the individual but someone must have an opinion.
Indy, he is 5' 8" and still wants to ride trails comfortably. I did 4" on my 05 switchback and it was about right and I am 5' 10".Go 5". I have 5" on my 05 xc sp and I love it. Had to extend the handwarmer wires, and the brake line. I did the brake line myself with some $2 brake line from Fleet Farm.
Im 5'9" and sitdown is very comfy.Indy, he is 5' 8" and still wants to ride trails comfortably. I did 4" on my 05 switchback and it was about right and I am 5' 10".
I just bought 6" of brake line and a fitting, connected it to the existing brake line, and bent it around a large pipe.Did you put an extension on it or replace the whole cable?
Do you have the PASS seat? If not I'd go 3.5"[/QUOTE said:
[<nbr>Q<nbr><nbr>UOTE=Do you have the PASS seat? If not I'd go 3.5"[<nbr>/QUOTE]
Yes
[QUOTE Do you have the PASS seat? If not I'd go 3.5" QUOTE]
Yes
</nbr><nbr>Do you have the PASS seat? If not I'd go 3.5"[<nbr>/QUOTE]
Yes
You might want to check this out:
You want a preview? Check out the Preview button on the lower right corner of the screen:Should have guessed you would come to my rescue. Felt pretty stupid after I screwed it up but apparently I cannot delete my posts. A preview feature would be nice so I can prevent myself from looking so stupid. If this doesn't work I'm really going to look dumb.
