Hi guys any ideas?
The kids 2000 indy 500 will start right up and run fine but when you come to a stop it wont idle down. When the issue first started at the end of last year you could hit the choke quick and it would idle down and stay there, this year it will idle down for 3-4 seconds and creep up to 3000 rpm quickly.
I sprayed wd40 around the carb boots, the back of the primary where the shaft comes in and about everywhere else with no change in idle.
I checked the compression and its at about 85 psi +/-.....
It has about 7500 miles on it and was rebuilt at about 3500 with a burned piston, wondering if that is happening again....
It has been ridden either wide open or on the brake its whole life and been a really good sled, I'd like to keep it around...
Thanks!
Jonesin
Thanks!
Jonesin
