http://www.youtube.com/watch?v=QTIGC8VsC3I&feature=sub
Here ya go doo guys and gals. A 600 4 stroke that gets 29 m.p.g. for 2011...
True, how many h.p. is the 600 E-Tek?? I would think aftermarket would get this to 70-80 h.p. pretty easy and still have really good mileage. Plus 4 stroke longevity. At least we know where doo is going now. Look at the first Yammy 4 strokes and where they are now. And I would say from what I have heard about the 1200 4-tek that doo is way ahead compaired to where Yammy was is 01....
put a clutch kit on it and gear it down, 60 hp nuff for me if i'm gettin 29 mpg
I doubt very much if there are any aftermarket companies that will be able to improve E-Tek performance by 20%. It is a very complicated, very sophisticated system best left alone. The aftermarket companies simply do not have the tech to even start modifying an E-Tech. Also, Yammi first put their R1 based 4 stroke in the RX1 in 2003, not 01. Since then they have added fuel injection and a lighter crank in 2006. For 2011 they are re-doing the fuel injection system. They still have the cross-plane R1 engine waiting in the wings. They have not been standing still. The 1200 'Doo motor is a welcome addition although it is not in the same league as the Yammi 4 banger unless it is turbo'd. They ALL have room for improvement but as time goes on things have become so complicated that soon the aftermarket companies will be supplying only things like skis and studs and clothing.
and i disagree about whether or not they will b able to come up with much of an aftermarket for the eteks, its a 6 dimensional fuel map and nearly impossible to tune without working from a stock dealership, weve been trying to contact all the major aftermarket companies because we want to try and get the etek to run off of ethanol and noone has anything even in development that can handle the level of computations that the etek does
I disagree. The automotive aftermarket has mods for new cars as soon as they hit the showroom. There are brilliant engineers in the aftermarket business, and I think it will be easy to mod future sleds. For most systems, all you should need is a remap of the electronic control systems, and you get instant power. That is the direction we are headed in. OEM's are conservative on the side of reliability. I am sure there is lots more power in all the new sleds just waiting to be found. It will be even less expensive to mod a modern sled because you won't need as many physical changes to acheive results.
