Here is my new wild child. Gonna be a long 4 months of waiting now.....
very nice, now while waiting you have lots of time to make some upgrades LOL
maybe get rid of the tri hub, the 14-15's were known to have bad non serviceable bearings in them
a GOOD tri hub replacement like the Larson racing, or JT will cure things and be a improvement at same time!
good idea to maybe re locate the fuse box, as its ina crappy place, if you ever blow a fuse, GOOD luck changing any trial side, unless you got some tiny hands and a sensitivity touch to blindly fight and replace fuses!
blow the OEM fuse for heated shield and your lights go out and all display and brake light?
SO< not a bad idea to wire that else where with a inline fuse you can actually get to!
then little knobs that replace the seat Allen bolt so you can take on and off with fingers is a real nice add one and not that costly!
float shock guards, just DON"T tighten them much at all they break when things get cold(I found you can fix a broken one with a zip tie and it will actually hold on better LOL)
a touring shield with mirrors makes life a LOT easier to keep tabs on ricky racers coming up behind you and or watching buddys!
SEE< lots things you can add and help pass the time till snow falls!
makes one realize just how the budget is never marge enough too HAHA!
