skidoolouie
Need a little help, have 02' chevy tahoe 140xxx miles that i thought oil pan gasket was leaking in the rear. So i replace with new fel-pro upon reinstalling i broke rear 6mm bolt cause it called for 108in lb and i put little more cause it kept leaking. Got bolt out after removing pan again and reinstalled 2nd new fel-pro and still is leaking near rear 2 long bolts when cold. I did tighten others to 37lb torque into block and the 2 in the 18lbs torque. Any one have ideas? Thanks
