95 formula ss 670 steers hard
csf
This sled has adjustment knob for the limiter strap,do I need to loosen or tighten strap to take some weight off the ski's? Any info will be greatly appreciated.
Thank's
What do you meen "steers hard"? Doesn't turn when riding and pushes through the corners or the steering is tight even when sitting in the garage??
csf
It doesn't push, goes where you point it,it takes more arm strenght to turn,compaired to other [older] sleds I have ridden.
Maybe my 2006 rev has spoiled me.
Maybe I got weak.
Thanks
csf
This is my son's sled,he would rather ride mine. Other friends have rode the formula and made mention about how hard it steers.It is not unbearable ,and it's a fun and fast machine.It would be nice if it would steer a little easier.
loosen the front limiter straps, tighten the rear limiter strap (if you have one), new bergstrom triple point carbides with the ez-steer plate
rp7x
arm strong
lift the frt of the sled off the ground if it's still tite your spindles are rusted
longtrack
Loosen front Strap and put more pressure on the front Skid Spring. That will lift the front of the Sled up. Also loosen the Ski Springs. You must transfer weight off the Ski's.
